Need opinion [SOLVED]
FiReFlY_tm
Post by FiReFlY_tm » Sun Sep 20, 2020 5:28 pm
so specs are:
Gigabyte X570 Aorus Elite (now bios F20, did tried two newers one also)
AMD Ryzen 3700X
EVGA 2070 super XC Gaming
4x8gb Corsair Vengeance PRO AMD 3600MHz (now running at stock 2666)
Corsair MP510 480GB
Corsair HX750W
EDIT: EKWB is custom water cooling loop im using.. and all the temperatures are fine nothing is overheating i even check with infrared meter
on W10 version 2004 ONLY in game i have BSOD. Everything else works fine.. seems to happen randomly no specific time table
On W10 version 1909 Game crashes but no BSOD... everything else works fine even on 3600MHz memory
I did tried swapping RAM (Kingston 3200MHz DDR4 HyperX), did tried one stick... or different combinations
I tested computer with
OCCT all tests passed (was having them for atleast 3hrs EACH - some even longer)
Furmark i had 3 and half hours no errors
Prime95 Each test for few hours - no errors
3dMark - runs perfectly
Only games are the issue... Crysis3 i was using for test crashes to windows same as BF5 but on both versions (BF5 gets BSOD on 2004)
All the components are brand new
EDIT 2: All the drivers are up to date... Extra drivers that i have beside the components is corsair icue for Corsair K70 keyboard and Logitech G Hub for the mouse G502 and Headset G635
So any opininions - except hammer!?
darkdeamon
Re: Need opinion
Post by darkdeamon » Mon Sep 21, 2020 4:39 am
Stay with 1909 for a while longer if you can
Lording it over the plebs and putting my hacks on your PC by many devious methods
FiReFlY_tm
Re: Need opinion
Post by FiReFlY_tm » Sat Oct 10, 2020 8:22 pm
well finally found whats the problem... it was actually bad cpu... brand new cpu thats crap...
Re: Need opinion
Post by Stujb » Sat Oct 10, 2020 8:46 pm
my opinion is you're gay
Re: Need opinion
Post by Spawnsy » Sun Oct 11, 2020 12:59 am
Helpful.
darkdeamon
Re: Need opinion
Post by darkdeamon » Sun Oct 11, 2020 2:54 am
As in just a bad chip or that particular model of chip?
FiReFlY_tm
Re: Need opinion
Post by FiReFlY_tm » Sun Oct 11, 2020 8:18 am
I bought two computers almost identical (well the one for the office doesnt have the same GPU and Same speed of Memory) so ive replaced all of the components now when i got time after two months... it is the bad CPU out of the box.. the whole series is performing marvelously and im impressed what im having with it (for 250€).. so im just gonna RMA the CPU.. but the strange thing is that it didnt started problems directly it started after 2 days when the windows update came out... so i was thinking all the time it was the update... when i got 1903 version it was little bit more stable but still got errors... i got lucky that all of the problems for me was in game.. windows was working fine...
This video shows exactly my problems (random bsod) but only in game...
You did concluded that after that night we spent together and while i was calling you my bitch?? i wasn´t gay that night.. i was sexually frustrated and you were there really exposed...
Re: Need opinion [SOLVED]
Post by Projectblue » Thu Nov 12, 2020 10:24 pm
Nice come back FiReFlY_tm :D
"Empty your mind, be formless, shapeless — like water. Now you put water in a cup, it becomes the cup; You put water into a bottle it becomes the bottle. Water can flow or it can crash. Be water, my friend.."
