Glitched Pistol Suppressors
Chat about our Insurgency server
Cairon
Leading Rate
Leading Rate
Steam: http://steamcommunity.com/id/DamnWhitePeople
Post by Cairon » Tue Aug 07, 2018 4:40 pm
Hi all,
Not sure if this issue has been raised or if it may just be on my end but when I add a suppressor to any pistol on our server it appears to have a mis-skinned suppressor.
Again I don't know if this is a problem on my end but I recall someone else mentioning it in Discord at some point.
Many thanks, Cairon.
Oreo spelt backwards is still oroe :cookie:
Steam: =EBS= Ztranier [DPT]/ http://steamcommunity.com/profiles/76561198008007768/
Re: Glitched Pistol Suppressors
Post by Ztranier » Tue Aug 07, 2018 5:34 pm
ahoy Cairon
it is not only on your end
we have that Problem for a couple of months now, because of the last NWI update, wich bugged lots of the customized files, but thanks to DD Monster amount of work we are still able to play on our INS Server!!!
however the silencers still do work even if the look wired
Cairon
Leading Rate
Leading Rate
Post by Cairon » Wed Aug 08, 2018 8:12 pm
Thanks for the response Ztranier!
I recall now about the update, just thought I would raise the issue and see if there is any way I can help resolve it.
Thanks, Cairon!
Post by Ztranier » Wed Aug 08, 2018 8:24 pm
that update is also the reason why you might miss a big bunch of nice maps we used to have on the rotation
DarkDeamon
Post by DarkDeamon » Thu Aug 09, 2018 10:39 am
I tried to resolve by editing the file causing the issue and it crashed the fucking server.
There are code errors within the mod files that cascade across several files and would mean editing about 8-10,000 lines of code, some of which are in files I don't have the correct decompiler for!
aka EvilB@stard
Insurgency Config maniac
Putting my hacks on your PC :devil:
Users browsing this forum: Bing [Bot] and 7 guests
