New Theater
New Theater
Post by DarkDeamon » Sat Feb 11, 2017 8:37 am
DarkD_v4_0 now running on server 1
You are advised to delete ALL DarKD off your system to clear out the old files.
Apart from the GL launcher glitch on the M16, all security classes have now been tested & I've not found any problems (so far). Weapon choice has been tweaked slightly. Please advise of any skateboarding bots.
I've taken out the 'test' armour and bullets and put the standard back in. Note, this means that the bullet damage has dropped. It's taking 2-3 body shots to take down someone with heavy armour though a headshot is a 1 shot kill (hint).
Will give it a couple of days of testing on this server before adding it to server 2.
Starting to prepare configs and theatres for customising server 2 but they will be based on DarkD_v4 so I need that working and tested 1st. This includes PvP as well as limited loadout maps
Will look at adding hunt maps on to 2 later this afternoon.
Re: New Theater
Post by taran » Sat Feb 11, 2017 8:39 am
sounds great, let me know if I can help.
Re: New Theater
Post by DarkDeamon » Sat Feb 11, 2017 9:50 am
Hunt maps are in. Currently only stock maps as I'd need to check which of the custom maps we've got is setup for hunt.
Stock maps gives us a few more maps to play with as they use some of the PvP maps. Set a base config file using the stock security/insurgent templates at the moment as i'm still working on the theater and need to play a few rounds of hunt 1st.
Re: New Theater
Post by DarkDeamon » Sat Feb 11, 2017 10:17 am
Ok, I need feedback on the hunt settings on server 2
Currently bot numbers set same as coop, 3:1 with 2 respawns. Playing solo was a case of hunt the bots once I'd blow the cache.
Need to know how you want the bots.
Taran, may want to try your AI changes on 2 also?
Hawkeye
Chief Petty Officer
Chief Petty Officer
Steam: http://steamcommunity.com/profiles/76561198001654666/
Re: New Theater
Post by Hawkeye » Sat Feb 11, 2017 1:27 pm
Thanks very much.
Just playing on server 1 with the peoples and notice the night vision isn't there for hijacked. Also rats 249 silencer has gone noisy again.
Re: New Theater
Post by DarkDeamon » Sat Feb 11, 2017 1:56 pm
Will check the night vision as I think I know what's wrong there.
249 issue, need to make sure all darkd files are removed and a clean lot downloaded
Hawkeye
Chief Petty Officer
Chief Petty Officer
Re: New Theater
Post by Hawkeye » Sat Feb 11, 2017 2:06 pm
When you're playing demolitions with c4 it let's you pick up an ied, if you lay the c4, then go to lay the ied all your guns and everything vanishes. They only come back once you swap a weapon off the ground.
Also the bots are maybe a bit too hard to kill. We seem to be struggling a bit.
Hawkeye
Chief Petty Officer
Chief Petty Officer
Re: New Theater
Post by Hawkeye » Sat Feb 11, 2017 2:14 pm
Yeah rat and 25 and hooter etc were in and I think we all deleted our files. I searched darkd on my C drive and got around 15 files and deleted all those before I started this morning. Is that the best way to find all of your theatre files?
Hawkeye
Chief Petty Officer
Chief Petty Officer
Re: New Theater
Post by Hawkeye » Sat Feb 11, 2017 2:27 pm
Rat rsv says he's seen a guy with an rpk on a skateboard and Teffie was being knifed by an invisible bot
Hawkeye
Chief Petty Officer
Chief Petty Officer
Re: New Theater
Post by Hawkeye » Sat Feb 11, 2017 2:45 pm
Just did a test of coming out of insurgency then deleting all the darkd files again and going in to server 1 first. Thought it might have been confused since I was on server 2 first this morning. But went in to server 1 After deleting the files and the silencer for the 249 still didn't work I'm afraid
Users browsing this forum: No registered users and 5 guests
