Change server 2 to an equal opportunities server.
Post by Spawnsy » Thu Feb 09, 2017 10:55 pm
This was mentioned on server 2 today. I said I'd get the ball rolling. Me and rat rsv have just talked though this joint offering. We think it's quite balanced, and a good starting point.
A server with all kits identical for equal opportunities.
Tailored loadouts for specific maps. The idea is to keep things really simple, quite 'bare-bones', and keep server 1 as was, or close to it. No C4, no tubes, otherwise everyone will have them, and it'll be silly. Same for burners, we can't have everyone with 3 each, it would ruin the game.
Majority maps kit.
All weapons with usual options of silencer and grips etc. Anything additional stated.
1x9mm 1x.45 1x shotty 1xsub. One of each.
Makarov + extended mag.
Shotgun +slugs +grip.
M45A1. extended mag.
MP5K.
1xcarbine 1xrifle 1xlight support 2xsniper options.
M4A1 Carbine. +MK4 + bipod to give sniper option.
FAL + 7X scope + bipod to give sniper option too. so i'm thinking these two cover the assualt and sniper choices needed.
Galil/or/RPK + bipod + drum if applicable. No auto! Gives larger mag option for some support.
2 flash
2 smoke
3 frags
1 burner
NVG
Ministry+Bunker Busting.
Pistol/shotgun only.
All pistols and shotgun.
2 flash
2 smoke
3 frags
1 burner
Maybe remove the ability to lose/pick up guns? Maybe do the same for bunker busting too? Could be good.
The Raid+Market.
Knife and Smoke. Nothing else. All pickups available.
If you want to change anything, please copy and edit the loadout above. Please give reasoning for your choices, and not just "but I like 'this' gun.". Bear in mind, the idea is to keep it simple, with minimum weapon options. If you can think of another map which you would like to see using a specific loadout, please say which map, what loadout, and why.
Hawkeye
Chief Petty Officer
Chief Petty Officer
Steam: http://steamcommunity.com/profiles/76561198001654666/
Re: Change server 2 to an equal opportunities server.
Post by Hawkeye » Fri Feb 10, 2017 12:02 pm
Start with that then, it'll be easier to judge once its running. Difficult to assess when it's only a theory. As I mentioned on Teffies post if it can be done I'd like to see some of the maps on the 2nd server turned in to PvP if it's possible to do them map by map. Also some Hunt maps would be a nice change. Played one with spadgy the other day while the servers were down and it was pretty fun.
Hawkeye
Chief Petty Officer
Chief Petty Officer
Post by Hawkeye » Fri Feb 10, 2017 12:03 pm
Would maybe change the one burner to one molotov, unless you can get a burner in a tight doorway or stair case they're more or less useless one at a time.
Post by DarkDeamon » Sat Feb 11, 2017 9:31 am
2 flash
2 smoke
3 frags
1 burner
'Pistol & shotgun' or 'pistol or shotgun'
Post by Spawnsy » Sat Feb 11, 2017 3:16 pm
or. only one weapon. like we usually would?
Post by DarkDeamon » Mon Feb 13, 2017 7:36 pm
Ok, we've got a pistols and shotty only theatre running on ministry on server 2 (fixed the primary weapon thing)
I'll do the same change for bunker busting tomorrow.
HOOTER
Post by HOOTER » Mon Feb 13, 2017 7:47 pm
Cheers Dark , good work !!!
Post by Spawnsy » Mon Feb 13, 2017 11:47 pm
Brilliant! Ty D. I can't wait to try it. Had some great fun this afternoon.
Post by DarkDeamon » Tue Feb 14, 2017 8:38 am
Smoke & Knives is running for market, the raid & jailbreak :devil:
Post by DarkDeamon » Tue Feb 14, 2017 5:23 pm
Got an issue with smoke and knives so I'm removing it for now but the pistols and shotty is working fine
