Lend your CPU/GPU to fight the Coronavirus
Re: Lend you CPU and/or GPU to fight the Coronavirus
Post by Ztranier » Thu Mar 26, 2020 1:27 pm
folding at medium my CPU went quite hot, up to 72°C wich might be to high IMO, unfortunatly when folding at low my GPU doesn´t start working
SpecOpsVX
=EBS= SpecOpsVX’s avatar
Post by SpecOpsVX » Thu Mar 26, 2020 6:48 pm
Yep I presumed it was my GPU because well GPU usage but no, it was my CPU that almost hit 90 degrees I've found out through my logs. Either way. For now, nope. :)
Image credit to Stuart Brown at Skipper Press. Check them out. Their art is something else! https://skipperpress.com/
Post by Ztranier » Thu Mar 26, 2020 7:02 pm
@kentone helped me out with some CPU fan software wich helped to pump up the fan rate and lower the core´s temp called SpeedFan
it is a bit complicate to set it propper up, but it helped
Post by 0v3rz34l0u5 » Thu Mar 26, 2020 9:39 pm
HonorOfDuty wrote:
Thu Mar 26, 2020 10:39 am
You can run Rosetta@Home in tandem with F@H so that you also get more CPU WUs
Rosetta@Home is a different ball game entirely (UC Berkeley). Folding@Home is a lot more intensive and hungry (Stanford Uni). I can’t use my Raspberry Pi to do folding.
Ghostie wrote:
Thu Mar 26, 2020 1:04 pm
Like the VM Ware link thanks 😁😁
Let me know how it goes!
@SpecOpsVX and @Ztranier, if you’d like, I can do some guides on how to stop folding on your CPU and concentrate entirely using your GPU?
In other news, Folding@Home has broken past the exaflop barrier and our team ranking has jumped up 5,240 places!
We’re not the avatars we create. We’re not the pictures on the film stock. We are the light that shines through. All else is just smoke and mirrors. Distracting, but not truly compelling.
Post by Spawnsy » Thu Mar 26, 2020 11:29 pm
That's frigging awesome.
rat-rsv
Post by rat-rsv » Fri Mar 27, 2020 9:39 am
found this could help with set up ff to 5.35
Post by Ztranier » Fri Mar 27, 2020 10:43 am
thx for sharing this find @rat-rsv
Post by 0v3rz34l0u5 » Fri Mar 27, 2020 11:27 am
Thanks for this @rat-rsv. If you're lazy like me, you can skip the waffle.
Post by Ztranier » Fri Mar 27, 2020 5:38 pm
yes Zel that would be nice to find a way to fold on low lvl and the gpu does´some work too since even with the new fan Setting the Cpu temerature i still on permanent 65°C with peaks above 70°C
Post by 0v3rz34l0u5 » Fri Mar 27, 2020 5:55 pm
What make and model GPU do you have? I have a Gigabyte Altus GTX1080Ti which does reach 70 odd degrees but ramping up the fans using their software pushes it down to 50 odd.
